Drill press tuning
Converting a cheap drill press into state of the art machinery
The quality of my drill press is more than mediocre, but it's designed like it was meant to be modded.
Modifications I'm got planned:
Column extension DONE
Lighting
Automated drive
Coordinate table
Vise
  • Column extension
    BF38 • 03/06/2016 at 12:35 • 0 comments
    The first mod was supposed to be quite simple, but it ended up being a little more complicated.
    One of the most annoying points of the drill press was the size of the column which prevented working on bigger pieces, so I decided to exchange the column, which looked easy because it's only a steel tube.
    Pict.1: Tiny cute drillpress (so kawaii ㅋ_ㅋ)
    When I measured the tube diameter it was 48 mm and I thought it was 48.3 mm, which is a standard size for handrails and is easy available, but I was wrong, it was really 48mm, which wasn't available at any nearby metal dealer, so I had to bore up the holes, which lead to the parallel project, the honing head.
    Pict.2: Column comparison
    I was really surprised it worked out so well, but the steel tube itself isn't really precise so I have already the next mod in mind, for being able to adjust the perpendicularity of the column.
    Pict.3: Quite a difference
View project log
chiara.sola wrote 03/15/2016 at 10:09 • point
wow!! keep the work bro!!
