- The tutorial
NFC shield connected on HSU): https://github.com/CITCEuraRFID/KeyDuinoAnd
the code with a badge/NFC ring is on the KeyDuino lib (example>relay shield).
- Problems
- WIP
This is a video tutorial: how to control your car door by NFC with a KeyDuino
car_doors.inoSMARTPHONE unlockingino - 2.87 kB - 02/06/2016 at 08:34 |
Nice project ! New arm chip arduinos with nRF52840 chip have embedded NFC reader support , have better sleep functionality and have also BLE functionality . So I think your next upgrade can be a build with a nrf52840 arduino and a relay shield only !
Salut Pierre,
Petite question je suis un débutant dans le Arduino et autres et je me demandais si j'utilise pas de shield sur qu'elle pin je doit connecté les fils du contact de déverrouillage du véhicule. Merci a l'avance...
