I received my new "bottom" case. Except a small problem with the micro card slot (1mm little too smal). Everything‘s perfect.
I changed the bottom case and everything works fine.
A project log for Retropie Portable Gaming Device
build a "gameboy" like device running retropie on a Raspberry Pi Zero
