A whole lot has happened since the last update. Here is what has happened in order
- Received Circuit Board V2 from OSHPark
- Created Wiring Harness
- Cut the tube to size
- Measured and made holes for servos
- Mounted Servos
- Mounted Thrust Section
- Fed Wire Harness up the rocket
- Epoxied everything together
After all that I am basically done other than I am getting my fins in tomorrow and will be installing them.
I did test all the servos and they work perfectly and am just waiting to get everything finished now.
Should all be ready to launch shortly.
Godspeed,
-Jeremy Hall
My Wiring Harness
Bottom of the rocket:
Whole Rocket!:
