Boards received and Abort!
09/17/2016 at 20:50 • 0 commentsI would love to thank OSHPark for getting my boards very quickly and for very cheap. They look wonderful, and I cannot wait to use them. I cannot recommend them enough for their prices and the nice looking Purple PCB. I am greatly happy with them and look forward to getting Version 2 made soon.
(I made minor errors on Version 1. The Servo pinout is not correct, and the clearance is a bit off between the sensor and microcontroller boards.)In other news, I finished debugging the abort system this morning while I was waiting to get the boards in the mail. It now works flawlessly and efficiently. With that abort code is done, my stabilization code is finished and all I have to do is calibration and flight readiness checks. I am rapidly completing this project and hope to have the entire thing launching by December.
On the note of Fins:
I am working my hardest to get the money to order fins for my rocket and should have the money for that shortly. Once I order those, I will have every part of my rocket complete and ready to go.Godspeed,
-Jeremy Hall
4 Pieces Left
09/12/2016 at 01:30 • 0 commentsThis week has been filled with a whole lot of measuring and designing and ordering. As you know, I got my PCB ordered. I also continued on to get my nose cone for the Rocket ordered. I managed to get it for cheap (about 15 dollars total) and it will be coming in Tuesday. I also managed to order myself the Epoxy needed to put this all together. That was the last of the money I had for the month. I am looking into ways to continue to get the 40 dollars I need to get fins laser cut and shipped to me.
I also realized I had a error on my PCB. It is not a major problem and just means I have to change the pins of my Servos which is not a big deal at all. I switched the power and ground signals on it and, I just have to move the wires in the molex connectors. I also got my newest sensor module, it is the same one I have been using for the prototype testing, but unfortunately I lost that one so I had to order another. I also ordered myself 400 male pins for my PCB so I can solder it on when it comes in (Hopefully soon.)Last night, I started designing the circuit board for Version 2 of my Rocket Control Board. It is now using a 32 bit microcontroller used in the Uno and the M0 Feather that Adafruit sells. It is a more complicated design, and I am adding microSD card support onboard, also I am adding Lipoly Charging and probably will have a USB connection for debugging. Stay tuned for that.
Godspeed
-Jeremy Hall
Rocket Control Boards Ordered
09/04/2016 at 14:06 • 1 commentI spent all of yesterday and most of this morning working on my first actual version that I have ordered from OSHPark. This is about my 3rd time designing this board and it came out wonderful and has became very small. Here are some images:
This is much smaller and more compact and I will probably be using this in my first launch if all goes well.
I will be uploading the schematics and board files to Github today and heres a link to the project on OSHPark if you want to order when I confirm they work properly. Order
Later today and tomorrow I will be designing the fins for this rocket and will probably be ordering them tomorrow.
Godspeed
-Jeremy Hall(Shoutout to OSHpark because they are awesome)
(Edit: Forgot links)
Houston, we have a problem!
08/20/2016 at 22:43 • 0 commentsI just uploaded my Version 1.9 of the Rocket Stabilization System code to Github! With this there are many changes
- Cleaned Up Code
- Abort! conditions
- Full Data-logging capabilities
- More customization options
- More functions!
- More rocket science!
All code is available on Github!
We have the pressure!
08/04/2016 at 00:48 • 0 commentsAfter a two more days of work I have finished code to get the BMP180 up and running and so far It seems to be pretty accurate (+-1m). I also took the chance and added SD logging functionality to the program so it can record telemetry on the way up.
As always code is on Github.
Godspeed!
We have achieved stability.
07/31/2016 at 16:17 • 0 commentsEver since I got my parts, I have been focused on getting it running. At first, I tried with a PID controller because that seemed like the most straightforward thing to do. Unfortunately, I was looking at it all wrong.
I looked at PID control theory and studied it as much as I could, but for some reason, I could not get it as near as stable as I would like. It just wouldn't want to go to the middle position unless it was 100% perfectly at 0. This makes sense because this is what PID controllers are designed to do. Unfortunately for a rocket, this type of movement would cause for crazy oscillations throughout the flight even with tuning of the controller. What I needed was a direct linear relationship between the Yaw, Pitch, and Roll and the rocket.
Yesterday, I started looking around and seeing what other people have done and saw this in common with the two people I looked at; they used the map function to map the gyro values directly to their control systems.
I thought to myself, "Woah, hold on here... This is too simple, this is suppose to be hard right?". I looked and I thought and I debated with myself on using this. I ran the tests, and it performed brilliantly. I no longer had to use a PID controller which will make the control system considerably faster and would be more responsive. It worked.
It works.
(Code is on Github.)
Rocket Parts!
07/11/2016 at 22:17 • 0 commentsThrough this busy time I have been working on getting some parts for the first prototype of the rocket. I ordered myself a 98mm (4") body tube and a 29mm motor mount for it. It has finally came in, along with these parts I have finished the basic code that I need to test with these parts. I will be posting the code once I get some final bugs with the roll figured out. Everything is going well for a test launch later this year or early next year.
(On another note, I am working on some safety systems for the rocket since it will be a mid-powered rocket and can pose some dangers with the system on the first few launches)
Prototype Circuit Board Design
06/08/2016 at 11:49 • 2 commentsI took the opportunity last night and this morning to go through and design myself a circuit board based on all the pin-outs of my components like my microSD card to SPI board and my GY-87 10DOF board and fit it with my pro-mini that I will be using.
Once I finalize my board design I will post both the board and schematic files here!
Currently this is my design for the circuit board:
On another note: I have published my filtering code on Github!
-Have a nice day!
It's been a while, but it is working!
05/15/2016 at 14:28 • 0 commentsIt's been a while since I posted an update, so here I go with a huge one.
Over the last few weeks, I have experimented with different kinds of filtering and I strayed away from Kalman filtering entirely. I have decided on using a Madgwick or Mahony Filter instead. The great news in this, through these many weeks I have worked hard and I finally got stable output using Madgwick and Mahony filtering. It took a lot of work to get it working without a single library other than the Arduino Wire library. It works great! Also, it seems to be running around 200 times a second, which I believe will be more than enough for what I need. My next step is to implement a PID control based on those 3 axes and the error that it strays away from perfect flight. Godspeed.
(I will be posting code on Github soon)
Log 1: Kalman
02/13/2016 at 13:38 • 3 commentsLog 1: Got a Basic Output using a Kalman filter, 10dof sensor should be coming in today. Will be posting code when done.
