Fixing errors, allowing new apertures and abandoning trigonometry.
A project log for Solder-stencil.me
Create 3d-printable STL solder stencils form Gerber files
robert-kirberichRobert Kirberich • 03/11/2016 at 15:31•0 Comments
Thanks to https://github.com/mancausoft I figured out that the whole wide aperture code I added yesterday wasn't correct - I replaced the logic used to thicken lines into rectangles which now works for circular and rectangular apertures (still making circular ones into rectangles though).
I also fixed a few bugs causing division by zero errors for circles with tiny areas and zero-length elements.
The main lesson here is to never use trigonometry for something that can be solved with vectors.
