I've been working on a few things. The first is an updated support forum at https://newae.com/forum which will serve as a method of users discussing the project. This is not only for ChipWhisperer-specific stuff, but any general open-source side-channel analysis projects (or that's the idea).
I've also updated the main Wiki Page with a little more clear links to information. Along with this I went through & updated the BOM + Build instructions for the ChipWhisperer Baseboard, and added those for the LNA + Differential Probe. So it's not major updates but makes things a lot more useful I think!
Finally on the SW side: the FPGA Project is now programmed from a zip file with all the partial reconfiguration information present. No longer do you need to deal with ensuring two different files match or worry about changing line ends when getting a file from GIT. The zip system makes your life easy.
