Ok, just a quick update about this little project.
First of all, a big Thank You to Hackaday.io and all the judges that thought this project was worthy of winning a Pi Zero! And a congratulations to the other 9 winners https://hackaday.io/contest/9326-adafruit-pi-zero-contest/log/32973-winners-of-the-10-pi-zeros
I have now sent off some new gerber files for an updated PCB. This gives more mechanical stability to the Pi Zero and fixes the composite output and should be in my Tindie store in a couple of weeks time.
Then install and run Screen;
sudo apt-get install screen
screen /dev/ttyAMA0 115200And you're good to go!
spencer
