Only a minor update here, but seeing that the Raspberry Pi foundation have updated the Pi Zero, I thought I should check that everything still works as expected with this RC2014 adapter board.
The most significant change is the addition of a camera header. This shouldn't affect this project, and everything else still seems pretty much the same, so I expected everything would work.
So, I soldered on the headers, inserted an SD card with Filippos PiGFX terminal software on, and yes! It still works just as planned!
Good work everybody!
spencer
