There's a bit of cleanup of the edges due to the print quality, but, I have a COMPLETELY modular design now. I think a better printer will produce better parts and make life much easier.
That's 3 Pi Zero slots in 1.25 x 4 inches. THESE will require a direct wire for power. I will be using JP1 & JP6 for the input. Same dimension as my original design.
