So, I decided to remove one of the laminates of the leaf on my Bramble design. I made a simple box fence around the open area of the middle laminate to eliminate one of the layers. Once I figure out how to affix the pi within the fence and on its supports, I will be able to eliminate both smaller laminates. If you get on Thingiverse, Look for my STL titled "Bramble Box - II".
