Share and Share-Alike
A project log for 8 Leaf Pi Zero Bramble
Modular design, small footprint Pi Zero Supercomputer
txdomsktxdo.msk 02/14/2016 at 21:170 Comments
Let's get a common filesystem going. Some of these things, you'll have to do after you get an actual Pi Zero going,like anything using the HEAD_IP, which will be the Raspi B. Right now, I am still on the Raspi B, building the final image which I will then copy to each SD card.
install/setup nfs clients
apt-get install nfs-common -y
mkdir -p /mnt/nfs
chown -R pi:pi /mnt/nfs
mount [HEAD_IP]:/volume1/nfs /mnt/nfs
Add this to /etc/fstab
[HEAD_IP]:/volume1/nfs /mnt/nfs nfs rw 0 0
