WOOT!
I got the basics down!
It all came down to getting the SSH-KEYGEN key swapping down right. There are some slight miscues from the articles I used as a basis, and I will be updating everything in due time and with more explanation to make things less confusing than what I have been thru. First, I will connect my second Leaf and set it up the same way and test it out though.
