This FirmWare got things going...
// set pin numbers:
const int sw2 = 2; // Down limit
const int sw3 = 3; // Up Limit
const int ledPin = 13; // Pwr L.E.D
const int ic1_2 = 8; // TA8409S IN2
const int ic1_1 = 9; // TA8409S IN1
const int enable = 10; // TA8409S Enable (motor)
boolean sw2State = HIGH; // Down Limit State
boolean sw3State = HIGH; // Up Limit State
void setup() {
Serial.begin(9600);
// Setting L.E.D and Motor In, Enable pins as an output:
pinMode(ic1_1, OUTPUT);
pinMode(ic1_2, OUTPUT);
pinMode(enable, OUTPUT);
pinMode(ledPin, OUTPUT);
// Setting limit switches pins as inputs
pinMode(sw2, INPUT_PULLUP);
pinMode(sw3, INPUT_PULLUP);
// Enables motor
digitalWrite(enable, 1);
//Starts program down
down();
void loop() {
// reads the state of the limit switches
//Serial.print("Reading SW2 State\n");
sw2State = digitalRead(sw2);
//Serial.print("Reading SW3 State\n");
sw3State = digitalRead(sw3);
if(debounce_sw3(sw3State) == LOW && sw3State == HIGH)
Serial.println("Up Limit Reached\n Going Down\n");
down();
sw3State = LOW;
if(debounce_sw2(sw2State) == LOW && sw2State == HIGH)
Serial.println("Down Limit Reached\n Going Up\n");
up();
sw2State = LOW;
boolean debounce_sw2(boolean state)
boolean stateNow = digitalRead(sw2);
if(state!=stateNow)
delay(10);
return stateNow;
boolean debounce_sw3(boolean state)
boolean stateNow = digitalRead(sw3);
if(state!=stateNow)
delay(10);
return stateNow;
void up() {
Serial.println("Up started\n");
digitalWrite(ic1_1, LOW);
digitalWrite(ic1_2, HIGH);
void down() {
Serial.println("Down started\n");
digitalWrite(ic1_1, HIGH);
digitalWrite(ic1_2, LOW);
void err() {
digitalWrite(enable, LOW);
