Hackaday.io Hackaday.io
Sign up Log in
Pi TV Stick
A dual antenna WiFi and Bluetooth adapter for the Raspberry Pi Zero with Wireless Display capabilities.
john-basistaJohn Basista
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.8k views
0 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.8k
0
10
9
Team (1)
  • john-basistaJohn Basista
Join this project's team
ongoing project
Related lists
Raspberry Pi Projects
Projects based on everyone's favorite low cost Linux Machine - The Raspberry Pi
This project is submitted for
  • Adafruit Pi Zero Contest
  • Enlightened Raspberry Pi
This project was created on 02/09/2016 and last updated 10 years ago.
Description
Google's Chromecast and Amazon's Fire TV Stick are great cheap devices that stream videos extremely well, but are not open source and easily modifiable. Intel's Compute Stick is a fully fledged tiny computer with Linux support, but is extremely costly and does not directly compete with cheaper variants. The Raspberry Pi is an affordable credit card sized, open platform Linux computer with a large community. And then came along the Raspberry Pi Zero. This gum stick sized computer makes for a perfect candidate for a Chromecast or Fire TV Stick variant which fits directly behind a TV. The only thing missing is WiFI capable of streaming video, which was usually added via USB. Since this board only has a Micro USB, it is not as easy to hook a USB WiFi Dongle up to the board, and even if one did, it would occupy the only USB port available to the user. Without access to USB, the only other answer is to use SDIO. And what way to make WiFi better than to add serial over
Components
  • 1 × TI WL1835MOD Bluetooth and WiFi SoC
  • 1 × TI TLV1117ADJ 1A LDO
  • 1 × STM32F042G6U6 Micro for BT UART comms and Enable Circuit, 28 Pin QFN, 4x4mm
  • 2 × ANT016008LCD2442MA1 2.4GHz Chip Antenna
  • 2 × TXS0108E Interface and IO ICs / Other Interface ICs
Project Logs
Collapse
  • Architecture Block Diagram
    John Basista • 02/09/2016 at 02:29 • 0 comments
    Architecture Block Diagram created to depict the signals needed to make this Pi Wireless Display Stick possible.
View project log
Log In/Sign up to comment
Sign up with Github
OR
hConsole is a portable computer with a lot of room for improvements and customizations.
Project Owner Contributor
hConsole Cyberdeck
hsaviorhsavior
Sheldon Kit would make your Raspberry Pi or Chromecast into All-in-one computer. Also it is a great second monitor on your desk
Sheldon Kit - The Mini HD Monitor
shieldonShieldon
Raspberry Pi Web Server Cluster running Raspbian-Linux, Apache, MariaDB and PHP.
LAMPi
developtheweb@DevelopTheWeb
Raspberry Pi 400 based cyberdeck using a non-functioning oscilloscope.
Oscilloscope Cyberdeck
jakoshadowsJak_o_Shadows
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Pi TV Stick", please tell us the reason.
Send message
Remove Member
