Yup, it's been one of those to-do things for quite some time. I've finally gotten around to it.
Summary of changes:
added a voltage plane
added a separate SPI header
Added a separate I2C header
consolidated a lot of the jumper pins to make life easier
Parts list for the new board:
kicad 5.0.2-1
Resistors:
3 10k ohm 0805
5 330 ohm 0805
2 220 ohm 0805
2 4.7K ohm 0805
1 1k ohm 0805
LDR resistor through-hole
Capacitors:
4 .1uF 0805
2 20pF 0805
optional TH smooothing cap
LEDs:
2 0805 LEDs (one for power, another one controlled by an I/O pin)
Pin headers(2.54mm):
2 20-pin
1 2-pin
2 4-pin
1 5-pin
1 6-pin
1 2x2-pin
1 2x6-pin
1 2x5-pin (recommend used shrouded socket)
Other stuff:
2 SS16 SMA diodes
1 THT:SW_PUSH_6mm reset button
40-pin socket for mcu
HC49-U through-hole crystal (16MHz)
for the transistor DMG2302UK or any mosfet/bipolar with a compatible pinout
