Humidity Tracker
A project log for Raspberry Pi Weather App
Using the Raspberry Pi to get weather from the internet
vaneh-boghosianVaneh Boghosian 06/04/2018 at 20:080 Comments
6/4
Created a semicircle marked with High/Medium/Low humidity ranges and converted the servo motor into a dial that moves according to the location the user inputs. Made some adjustments to the code so the dial will stay on the high/medium/low instead of resetting to zero at the end of the program (now it resets to zero at the beginning of the program).  Below the GIF shows the humidity when I set the location to Hawaii.
