6/4
Created a semicircle marked with High/Medium/Low humidity ranges and converted the servo motor into a dial that moves according to the location the user inputs. Made some adjustments to the code so the dial will stay on the high/medium/low instead of resetting to zero at the end of the program (now it resets to zero at the beginning of the program). Below the GIF shows the humidity when I set the location to Hawaii.
![](https://media.giphy.com/media/lVBWrpa26Nn5BPhtgp/giphy.gif)
