Heat Sink Housing
A project log for Coffee/Tea Cooling Buddy
Monitor the temperature of your drink and know when it reaches the perfect temperature. Even generates a tiny bit of electricity too!
scott-clandininScott Clandinin 05/21/2018 at 21:030 Comments
I've done up a rough prototype housing 3D printed with PLA to confirm my dimensions were good and for easier testing.
It printed a bit wonky on the bottom but good enough.
I did another test with the hot mug and was able to yield 260mV at peak. I still have not applied the thermal paste between the surfaces of the thermoelectric generator. I ran the fan from a separate 5V source to see the effect on produced voltage. I was able to get up to 290mV peak thanks to the extra temperature differential.
