We're looking for a low cost SBC with a more powerful CPU and multichannel I2S port (e.g. Freescale i.MX series or TI AM5728) to achieve a lower latency and implement more complex audio effects or synthesizers. The Allwinner SoCs seem to be a good choice, too. Unfortunately the ASoC platform driver for the Enhanced Serial Audio Interface (ESAI) of Allwinner SoCs only support 2 audio channels. We appreciate any suggestions.
Quad channel output on Teensy:
https://forum.pjrc.com/threads/29373-Bit-bang-multiple-I2S-inputs-simultaneously?s=f4fcb7428ac1e64fb4310eef71174e0f&p=93521&viewfull=1#post93521
SBCs:
https://www.pine64.com/
http://www.up-board.org/
http://www.hardkernel.com/main/products/prdt_info.php
Iancanada's I2S FIFO Project on diyaudio could be interesting for you as well:
http://www.diyaudio.com/forums/digital-line-level/192465-asynchronous-i2s-fifo-project-ultimate-weapon-fight-jitter-367.html#post4424605
I2S FIFO with BBB
http://www.diyaudio.com/forums/digital-line-level/192465-asynchronous-i2s-fifo-project-ultimate-weapon-fight-jitter-419.html#post4671302
Multi channel FIFO is being designed, Ian is open to suggestions:
http://www.diyaudio.com/forums/digital-line-level/192465-asynchronous-i2s-fifo-project-ultimate-weapon-fight-jitter-401.html#post4589962
