It's in my links, but in case you don't see it, here is my part list on Mouser that I've been using. I've finished updating it with all of the passives. I do need to make a test version attributing part names to the part, but the actual parts and quantity are accurate for the mainboard revision "Proto 3.4".
Edit: Link removed. There are a few problems with the list and I'm correcting them now. I'll post the link on the main page when it has been corrected.
Since there are still problems with the design, I've not wanted to released it. As it stands:
- The primary issue is that the JTAG TDO pin is tied to the a ground pin on the "JTAG" uUSB receptacle by the ICSP headers. If a cable is plugged into this port, you'll be shorting the TDO pin to ground.
- AN Input uUSB receptacles 6&7, 8&9, 10&11, and 12&13 and too close to each other for a standard cable. As such the connecting cables have to have the jackets of their plugs trimmed to a low profile of about 0.2".
Everything else should be fine, but I won't know until I fully test the prototype etc. After work today, I'll upload the schematic and board layout to GitHub. I need to annotate various portions of work.
From this BOM I'll be able to jot out the Display Boards much more quickly.
