Can anyone test this out? It should work on all platforms, I tested it on Linux and Mac OSX.
I have had no issues with the latest version in the repository, it produces no errors that I can see.
I hope this helps some of you out! Thanks!
A project log for Gcode Manipulator
Why G53 zero your CNC machine when you could just MOVE YOUR CODE to the origin!
