Low Pass Filter for PWM
A project log for DIY Harmonic Drive Equatorial Mount
A home built equatorial mount for my telescope built mostly recycled components I have had lying around.
jerry-biehlerJerry Biehler • 03/09/2015 at 21:41•0 Comments
I used LTSpice last night to do some circuit simulation. I hooked up the SiTech controller to the scope and found it uses a 23.45khz base frequency. Popping this info into LTSpice allowed me to come up with a pretty simple 2 pole low pass filter that should give me reasonable ripple and good step response with a 10v max output.
