• Using a hex buffer to drive the LCD
    Sophi Kravitz • 01/15/2017 at 21:15 • 11 comments
    I hadn't looked at this project in awhile, and discovered that way back when I'd ordered some inverters and XOR gates! Free parts, just sitting there.
    So I built a quick circuit with one of the hex inverters (CD4049) to drive the glass:
    The formula for frequency is determined by R1 and C1 is F = 1 / (1.39xRxC) ... I tried with a 47k resistor and a 330k. In both cases, the glass appears dark.
    What I want though, is for the glass to be able to dim. The correct driving wave form should look like this, but in order to vary the brightness/ dimming, needs a PWM signal.
  • reference links
    Sophi Kravitz • 02/26/2016 at 20:00 • 0 comments
  • Progress images
    Sophi Kravitz • 02/14/2016 at 20:59 • 0 comments
    Signal of input (channel 2) and output (channel 1) in and out of the inverter.
    The signal is from an Arduino
    analogWrite(shutterThree, 65);
