- Filleting around corners
- Larger HDMI hole so it doesn't pull out as easy
- Pi Zero pulled further back into case. Only SD card is exposed now. Previous version had a part of the Pi Zero board exposed.
I will be moving the files to Thingiverse. However, it won't let me publish for 24 hours after creating a new account. In the mean time I've attached the files to this project.
