This is a table with some possible combinations for the sonic screwdriver.
Menu | input | output | combination result |
DAZZ | rgb led, white led | Randomized switching of the LEDs like in the link - a non lethal weapon a doctor may approve. http://hackaday.com/2009/09/28/open-source-weapon-makes-you-puke/ | |
MAESTRO | accelerometer | rgb led | throwing the ssd would result in a colorful representation of the forces on each axis see the example "mpu2rgb" |
THEREMIN | photoresistor | piezo speaker | also known as a light theremin |
N/A | accelerometer + photoresistor | serial console | 3D scanning devise (probably very crude) |
N/A | fader | piezo speaker | a trumpet or flute like instrument |
N/A | accelerometer | IR led | controlling IR helicopters and cars remotely |
N/A | piezo speaker, bar graph | metronome, using bargraph as binary display to show bpm / 10 | |
N/A | accelerometer | piezo speaker | alarm triggered by movement |
