A special thanks to everybody that has liked/followed my project. I just found out Hackaday is giving out seed money and so far I've been awarded some, so make that double thanks for the likes/skulls!
This has me thinking about doing a board giveaway later on this year as a way to give something back to the community. The winner(s) would get a board either assembled or in kit form (whichever form the winner(s) would like to receive it in) and I'll probably throw in a USBasp.
Again, I'm still taking suggestions for a 4th revision of the board.
This dev board is great.
I've got a lot of projects that could/should have used an ATTiny chip, but not being particularly experienced/comfortable with flashing/programming them put me off. Using something like this would definitely help simplify the process; plug in your chip, plug in your cable and off you go!
Great work :)
Thanks for the words of support and finding my board useful. I'm thinking about doing some dev boards for other mcu's such as the Atmega1284p.
Do it, buddy. Do it. If you can produce this level of 'easue of use' for other mcu's that can only be a good thing.
It would definitely let me expand and start using other mcus other than arduinos!
