Raspberry pi zero powered glasses using Ntsc glasses from adafruit. Hacked into making the cool, stylish, and nerdy pi glasses.
The first thing you should do is solder 2 wires to the 3rd and 4rth pin on the power boost 1000c
Second step: the second thing you should do is solder 2 wires to the power and ground pin on the power boost
Third step: solder the ends of the wires you just soldered to the power boost to the power pins on the pi zero
