StickScope v3.scadThe final design (so far)scad - 4.02 kB - 02/28/2016 at 08:29 |
StickScope v2.scadThe v2 design (the v1 was so useless, that doesn't worth to publish). Not recommended to print as the v3 is on its way.scad - 4.15 kB - 02/27/2016 at 22:53 |
As I found while building the previous design, that the microscope can't be used on the parts close to the bar where the microscope itself is mounted.
So yesterday late night, changed the design, printed and assembled it in the morning.
I was thinking about for a while, how to attach a microscope to the stickvise. It became handy to have a microscope while soldering tiny SMD parts.
After a few weeks of thinking, tweaking, finally I developed a working prototype.
This is the second version. The first one had a monolithic cross section block, what used to much plastic, wasn't easily printable, and hard to handle.
After I assembled this model just realized a major design flaw. The microscope can't be positioned close to the bar of the stickvise where it is mounted. So I decided to tweak it a bit, so a newer version (v3) will come shortly.
Hi,
Nope. Even I was running a quick test session tonight with 4 microscopes. I wasn't seen any lagging at all (Core i7 notebook, intel video). Actually I guess that the lagging may produced by the slow machine or the badly written handling software - I used a software written by myself for a work project previously based on aforge.net.
I seen actually two problems with the cheap eBay microscopes:
- too big magnification. 50x minimal magnification make it useless
- lack of polarizing filter. It makes the internal lighting completely useless
I'll write a project log on it tomorrow, as now getting too late here.
I have that scope and the mount that came with it is horrible. This is a great use of a 3D printer. Have you figure out how to get the delay out of the scope? I find it's not possible to solder under it with such a lag.
Hi,
Thanks for the skull! To be honest, I haven't tried it yet because I didn't finished the setup of the PC, what is going onto my workshop desk.
I'll try it soon and come back with the result.
awesome, love it man! one thing from the components list - what is the model/size scope you used?
Have you tried the "Andonstar"-type usb microscope? I've borrowed one and they seem to be better (and less laggy) for PCB use: http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=andonstar 500x&rt=nc&LH_PrefLoc=98&_trksid=p2045573.m1684
