The original schematic from Netflix looked pretty complicated, so I spend one evening to clean it up and reproduce it in Fritzing. I removed the charging circuit and the switch, as they are already located on the Lilypad.
The original Netflix schematic
After a good night sleep I fixed some problems (it is always a good idea to check and doublecheck before starting to build something).
