NEDONAND-3 is 4-bit synchronous counter with parallel load and asynchronous clear similar to 74161 chip:
This is assembled one:
This how it looks with connected two NEDONAND-2 boards (dual edge-controlled D-triggers):
So it's 26 chips 74F00 implementing a single 74161 ;)
BTW it's eating about 130 mA constantly,,,
Now you have a rough idea of the total power consumption of your system :-)
Yes, but TTL is TTL ;)
Single-board version will be CMOS only :)
4 red LEDs are counted bits and 5th yellow LED is a signal of enabling counting for the next stage of the counter (next 4 bits)
