NEDONAND-8 is one multiplexer 8:1 controlled by 3 address inputs - see "mux8" in nedonand.circ:
Eagle v5.12 circuit replicates the same approach:
And it's already ordered through OSHPark (but not yet shared there because I need to test it first):
Pins description:
1) GND - ground 2) I0 - input if A=0 3) I1 - input if A=1 4) I2 - input if A=2 5) I3 - input if A=3 6) I4 - input if A=4 7) I5 - input if A=5 8) I6 - input if A=6 9) I7 - input if A=7 10)OUT - output of multiplexer 11)NC - not connected 12)VCC - power +5V 13)GND - another ground 14)A0 - bit 0 of address 15)A1 - bit 1 of address 16)A2 - bit 2 of address
