Another test
A project log for NEDONAND homebrew computer
NEDONAND is 8-bit homebrew computer entirely built out of many 74F00 chips (2-input NAND gates)
shaosSHAOS • 03/10/2016 at 05:57•2 Comments
Just put together NEDONAND-3 with 2 NEDONAND-2 and NEDONAND-16 ROM "programmed" with 4-bit to Hex converter to display 4-bit address in human readable format:
This is ROM alone (I drilled a few holes and installed 7-segment indicator directly on the board):
Yann Guidon / YGDES wrote 03/10/2016 at 09:23 • point
Negative logic, I see :-)
SHAOS wrote 03/10/2016 at 15:23 • point
Yes, because LEDs must be connected between power and TTL outputs to work properly with TTL so all lights are inverted - then I used diodes for "zeros" instead of "ones" (it's actually less diodes in this case ; )
P.S. In true ROM application with the same board it will be diodes for "ones" though...
