Date: 2/11/2016
I finally received my long-awaited flip-dot display from AlfaZeta, shipped from Poland.
Even though I plan to use a Raspberry Pi to control the display, I used an Arduino with a SparkFun RS-485 Transceiver Breakout Board (BOB-10124) for testing. AlfaZeta was kind enough to send me some sample code for the Arduino, so that was a pretty obvious choice to start.
Arduino Code Sample from AlfaZeta:
// 0x80 beginning
//___________________
// 0x81 - 112 bytes / no refresh / C+3E
// 0x82 - refresh
// 0x83 - 28 bytes of data / refresh / 2C
// 0x84 - 28 bytes of data / no refresh / 2C
// 0x85 - 56 bytes of data / refresh / C+E
// 0x86 - 56 bytes of data / no refresh / C+E
// address or 0xFF for all
// data ... 1 to nuber of data bytes
// 0x8F end
// panel's speed setting: 1-OFF 2-ON 3 - ON
// panel address : 1 (8 pos dip switch: 1:on 2 -8: off)
// I was using RS485 Breakout and Duemilanova connected in the following way:
// [Panel] [RS485] [Arduino]
// 485+ A
// 485- B
// 3-5V 5V
// RX-I TX
// TX-O Not connected
// RTS 5V
// GND GND
// these are blank transmissions for various controller configurations: CE - one controller + one extension, 2C - two controllers (the most popular), C3E - one controller + threee extensions
// you can use them by putting data bytes
byte sign_CE[]= {0x80, 0x85, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8F};
byte sign_2C[]= {0x80, 0x85, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8F};
byte sign_C3E[]= {0x80, 0x85, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// dark / bright transmissions for configurations above
byte all_bright_CE[]= {0x80, 0x85, 0x01, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F,
0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x8F};
byte all_bright_2C[]= {0x80, 0x85, 0x01, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x8F};
byte all_bright_C3E[]= {0x80, 0x85, 0x01, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F,
byte all_dark_CE[]= {0x80, 0x85, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
byte all_dark_2C[]= {0x80, 0x85, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8F};
byte all_dark_C3E[]= {0x80, 0x85, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
void setup() {
Serial.begin(57600);
void loop() {
// delay between transmissions: 200 ms is a safe value for CE configuration, you can play with this. For 2C you should be able to ge down to 100 ms
int delay_tr = 200;
// CE
// Serial.write(all_dark_CE, 60);
// delay (delay_tr);
// Serial.write(all_bright_CE, 60);
// 2C
Serial.write(all_dark_2C, 32);
delay (200);
Serial.write(all_bright_2C, 32);
delay (200);
// C3E
// Serial.write(all_dark_C3E, 116);
// delay (200);
// delay (200);
