Assembly - LED Carriage
A project log for Networked Low Resolution DMD Projectors
WiFi networked electro-mechanical 7x7 pixel flip-dot displays as giant DMDs (Digital Micromirror Devices) for low resolution projection
michael-shaubMichael Shaub 02/25/2016 at 05:160 Comments
With the Flashlight cut down and wired up to a USB cable, the LED carriage could be assembled. Unfortunately, my T-Bolt assembly didn't work that well here. I ended up gluing the nuts into position before assembly so they wouldn't fall out when I loosened things.
Rich text editor
