Date: 2/19/2016
I wanted to try something more interesting than test patterns on the flip dot display. I'd played a little bit with high speed to see how quickly the dots could respond which got me thinking about making something that ran in real-time. I wrote a program that showed a preview of the flip-dot display, allowed a mouse left-click to "draw" a white dot and a right-click to "erase" it back to black. I added a highlight around each dot location like a "mouse over" event to make it easier to see the mouse location.
Below is the code for the Live Drawing processing sketch:
// Live Draw sketch
// For LinkSprite V3 and AlfaZeta flip-dot display
// by Michael Shaub 2016
import processing.serial.*;
// The serial port:
Serial myPort;
PImage pix = createImage(7, 7, RGB);
int frameDelay = 50; //pause 400 ms between frames being sent to the board
float dotSize = 0;
void setup() {
// List all the available serial ports:
printArray(Serial.list());
// Open the port you are using at the rate you want:
myPort = new Serial(this, Serial.list()[0], 57600);
size(500,500);
dotSize = height/7.0;
pix.loadPixels();
for (int i = 0; i < pix.pixels.length; i++) {
pix.pixels[i] = color(0);
pix.updatePixels();
noStroke();
ellipseMode(CORNER);
void draw(){
background(0);
boolean dot = false;
pix.loadPixels();
//bitshift values from array
int row1 = 0;
int row2 = 0;
int row3 = 0;
int row4 = 0;
int row5 = 0;
int row6 = 0;
int row7 = 0;
for (int y = 0; y < pix.height; y++) {
for (int x = 0; x < pix.width; x++) {
stroke(64);
strokeWeight(1);
noFill();
ellipse(x*dotSize,y*dotSize,dotSize,dotSize);
noStroke();
if( pix.pixels[x+y*pix.width] == color(255) ){
//draw on screen
fill(255);
if(round(mouseX/dotSize-.5)==x && round(mouseY/dotSize-.5)==y){
stroke(128);
strokeWeight(4);
noFill();
noStroke();
if (mousePressed && (mouseButton == LEFT)) {
pix.pixels[x+y*pix.width] = color(255);
if (mousePressed && (mouseButton == RIGHT)) {
pix.pixels[x+y*pix.width] = color(0);
pix.updatePixels();
pix.loadPixels();
//prep for fipDot message
int b = 1 << x; //bitshift the value the number of positions equal to the digit
switch(y+1){
case 1:
row1 = row1 | b; //bitwise OR addition of the "b" value to the existing "row3" value
break;
case 2:
row2 = row2 | b; //bitwise OR addition of the "b" value to the existing "row3" value
break;
case 3:
row3 = row3 | b; //bitwise OR addition of the "b" value to the existing "row3" value
break;
case 4:
row4 = row4 | b; //bitwise OR addition of the "b" value to the existing "row3" value
break;
case 5:
row5 = row5 | b; //bitwise OR addition of the "b" value to the existing "row3" value
break;
case 6:
row6 = row6 | b; //bitwise OR addition of the "b" value to the existing "row3" value
break;
case 7:
row7 = row7 | b; //bitwise OR addition of the "b" value to the existing "row3" value
break;
pix.updatePixels();
int test_2[]= {0x80, 0x87, 0xFF, row1, row2, row3, row4, row5, row6, row7, 0x8F};
for(int i=0; i<test_2.length; i++){
myPort.write(test_2[i]);
delay (frameDelay);
