Nothing to see here. An Amazon Dash splayed out in the spirit of dekuNukem's git repository.
I'm mildly interested in hooking this up to my ST-Link V2, because "hacking" it with a Node.js or python script running on a Raspberry Pi is kind of played out... and cheating.
After this picture was taken, the 26AWG wiring ripped the SWCLK pad clean off. A bit of Googling shows that a AXE610124 fits the connector header to the right of the pads. I found continuity between SWDIO and one of the pins, so maybe it'll work. I've ordered a few from Digi-Key and we'll see what happens...
Hot glue! On multiple points along the wire, anchoring it to other parts of the PCB.
I've lifted pads way too many times :
