I was trying to figure out why I could only successfully write and erase a sector of my Dash's flash once. On the left is the data sheet for the M25P16, the middle are the SPI commands that Broadcom's WICED SDK uses to erase a sector and the entire chip, and on the right is the data sheet for the SST25VF016B.
Nothing lines up!
