Protomaker 3D Printer Hacked Probe details
Hacked Auto level Probe details
Hacked Auto level Probe details: This is a manual probe
Two microswitches in series so if ether one is Triggerd, (open), it will get a signal
Not tested fully but it appears as if the Auto level height takes over some-how and can cause the side Z end stop to get knocked down. This is even though these two switches are connected in series, like one switch.
I play this music for some time, it is in the Start G-Code via Display LCD 12864 full graphic smart controller and using RAMPS 1.4 and Ardunio Mega Using G29 Auto level, tramming, routine
Protomaker Black Sprint Original 3D Printer advertised for spares or repairs.
It may take some time to get this 3D printer working to a level where it is usable due to lack of budget
  • 1 × microswitch To sence Auto level
  • 1 × Computer expansion plates Used to fasted the switch to the 3D Printer
  • 1 × Bolts spring and washer To allow movement of probe switch up out the way or down in use
