Hackaday.io Hackaday.io
Sign up Log in
POV Display (Persistence of vision)
A POV display using a ATTiny2313 uC , a HC_06 Bluetooth Module and shift registers with few LEDs
foxmjayFoxmjay
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.1k views
0 comments
42 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1.1k
0
42
13
Team (1)
  • foxmjayFoxmjay
Join this project's team
hardware
ongoing project
POV Display
Related lists
projects
stuff
This project was created on 02/26/2016 and last updated 11 years ago.
Description
A fascinating project to try out , the outcome is really beautiful . The idea is to add the internet of things capabilities to the POV display , that's the reason for the HC_06 BT module , which will be getting all the data to display through an android App . for the time being the display shows the clock only .
Details
Components
  • 1 × ATTiny2313 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × HC_06 Bluetooth Module
  • 32 × SMD LED
  • 2 × 74HC595D shift register Logic ICs / Flip-Flops, Latches, Registers
Log In/Sign up to comment
Sign up with Github
OR
Bluetooth terminal to display short messages on 16x2 character LCD
Project Owner Contributor
Bluetooth Short Message Display Terminal
ankit-bhatnagarAnkit Bhatnagar
4 chainable, 7 seg digit display , controlled via MAX7219
Yet another MAX7219 , 1 inche 7 seg digit display
zanzeoozanzeoo
Esp8266 based Internet connected tiny display driver for 128x64 OLED I2C Display that can show any data or information from the web
IOT Display
sayantan-palSAYANTAN PAL
Display a graphic
Miro
kawikawi
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "POV Display (Persistence of vision)", please tell us the reason.
Send message
Remove Member
