My latest relay board solution is based upon information from this Instructable. It uses the "SainSmart 5V 2-Channel Solid State Relay Board for Arduino Uno Duemilanove MEGA2560 MEGA1280 ARM DSP PIC" for about $16 via Amazon.
- (2) Solid State Relays
- Power Supply: 5VDC 160mA (all channels ON)
- Input Ctrl Sig:
- 0-0.5V = LOW
- 2.5-20V = HIGH
- Load: 75-264VAC, 0.1-2A
- Phototriac isolation
Concerns:
Output/Load/Switching side of relay on works as expected for AC loads. If DC load, it latches when activated, waiting on AC cycle to reset it--which of course never happens.
