All of the wheelbase components are modeled except the structure that holds everything together. We decided to laser-cut it in acrylic plastic, using the less quantity possible to keep the cost down.
Acrylic is transparent, so the motor/gear/wheels system will be visible, for educational and checking purposes.
newdrive
