Generating ink from pollution sources and using it to feed printers.
What a fantastic idea. I'd love to see some numbers with how much printing you can get done per unit of soot. Would be fantastic to see this continued.
This is a great idea, you need more attention towards this project!!
This is really a great idea. By applying one can not only save the environment but also reduce the existing pollutant in the environment. Black ink is widely used in sublimation printing. you can see
https://bestsublimationoutlet.com/will-acetone-remove-sublimation-ink/
