Ordering parts in a few days!!!
A project log for GimbalBot
Gimbaled thrusters, aerospace-grade adhesives, carbon-fiber-reinforced polymers, and inertial measurement units. This is a space project!
zakqwyzakqwy 07/14/2014 at 03:148 Comments
... and I'd love your feedback. Seriously! This is design iteration number 8, and I'm ready to lock it down and put in a major CFRP order. I'm planning on sleeping on this and maybe tinkering a bit more tomorrow or Tuesday, but I don't want to make many more changes. Time to build a prototype.
A few quick (and rough) specifications for v08:
Okay, so what's new? Be brief, Zach!
No more reaction wheel. I've gone in to depth on this decision previously, so I won't belabor the point here; needless to say, this choice makes a lot of things simpler and lighter:
See? Isn't that a simpler battery compartment? Also notice the largeness of the battery; I'm using a 3S 6000mA unit. The Arduino and various other bits will mount to the underside of the top plate.
Back to the original X/Y thrust vectoring design. It's somewhat proven and should dramatically improve reaction time (again, see the previous post; I'm talking 50 Hz vs 6 Hz, so nearly an order of magnitude improvement. At least on paper...).
Yeah, I know the linkages aren't quite parallel... I got a bit lazy with my measuring. Stuff to note here:
More power!! You noticed that thrust:weight ratio, right?? Yeah, I'm hoping to see maximum thrust in the 2.8kg range. How?
Back-calculating from the prop thrust tester, I'll need ~10k rpm to hit 1.8kg thrust at about 170W/motor. Given 80% motor efficiency and a bit of extra power draw from sensors, controllers, servos, etc, I'm estimating average power consumption at 500W or so. 6000mA 3S battery-->66W-hr capacity-->8ish minutes of run time at a hover. I'll take it, even if it's half that figure in reality.
Stuff that isn't shown (but is included in the weight estimate)
More to come early this week. Comments welcome!
- Zach
Rich text editor
curtis.layton wrote 07/15/2014 at 11:01 point
Just a quick thought - when running signal cabling from the bottom of the rig to the top, try to keep them away from the motor power wires. If you need to, use differential signaling. Also, with all of your high current wiring, twist the negative and positive together (or the three phase wires) to minimize the current loop area. No use in making a giant EMI noise maker!
The only other thing that you should probably add to your shopping list is a good supply of spare props!
zakqwy wrote 07/15/2014 at 12:42 point
Great call on the EMI. A few thoughts I've had here:
- The motor controllers are fairly close to the motors themselves; ideally, this will keep most of the noise a solid meter away from the control circuitry. I should probably scope the speed controller power wires on the test rig to see how the controllers affect the power loop.
- Think the CFRP tube is conductive enough to use as a shield? If I can ground it, maybe I could run the power wires along the outside and stuff all the signal wires into the hollow portion of the frame.
- I'll keep the twisting recommendation in mind. Fortunately, silicone wire is super flexible.
- Think I should spring for shielded cable for the servo controls? I'll definitely use it for the tachs. How would I set up a differential pair for PWM servos, since they're single-ended? I would need some circuitry near the servos themselves, right?
- Props are, miraculously, quite cheap. I've got a few sets and will probably spring for a few more. The CFRP ones in particular are fairly brittle.
Thanks Curtis!
PointyOintment wrote 07/15/2014 at 19:28 point
zakqwy, where do you buy your props? I've never found CFRP props to be cheap when I've looked.
zakqwy wrote 07/15/2014 at 20:45 point
I'm getting 'em from Altitude Hobbies. A pair of 9x4.7 Gemfan CFRP is $8.99; not nearly as cheap as their nylon version (at under $3/pair), but still not bad. I'm new to the scene though, so maybe that's not terribly cheap.
Jefito wrote 07/15/2014 at 03:23 point
Can't wait to see this thing come together! Here's some sundry thoughts:
How do you plan to test this thing? A test plan would be a good idea, since there might be some physical, electrical, and software hooks you want to add for debug, etc.
At some point you're probably going to want to untether it and let it fly free... and it will crash. You mentioned landing gear, but I would be more pessimistic and look at protecting everything. I'm most concerned about the unguarded rotors and linkages. It wouldn't take much of a hit to kill those servos.
A neat approach would be something like NASAs super ball bot, which uses a tensegrity based super structure to absorb impacts. Fun fact, one of the younger guys from Case is working on that robot.
zakqwy wrote 07/15/2014 at 13:44 point
You're absolutely right; it will crash. A testing plan is a good call! In my mind, the general outline went like this:
1. Fully constrained testing. I'll likely build an adapter for my thrust testing rig that clamps around GimbalBot's tube frame; this will allow me to verify static thrust, work the bugs out of the tachs, and test the servo actuation under load.
2. Laterally constrained testing. I'll support GimbalBot using a few rings around the tube frame, suspended by wires on a frame in my basement. This will allow a foot or so of free vertical movement while preventing forward/backward or side-to-side pitching. This testing routine will be used to start fiddling with the vertical stability loop and to quantify roll axis response rate.
3. Tethered testing. I'll modify the laterally constrained testing rig to give GimbalBot a bit more leeway in the pitching axes; this will allow me to start tuning the other stability loops and quantify the control response rate from the servo mechanisms. In particular, I want to figure out linkage ratios here. The tethers will mostly be in place to keep GimbalBot from crashing.
4. ??? That's about as far as I've gotten at this point. What's the next step before fully untethered outdoor flight?
Good call on the servos; I was focused on protecting the props and reinforcing CFRP joints, but I didn't think about linkage protection; even a moderate hit on any part of the pitch ring will send a severe shock through the servo linkage and probably strip out a gear or two. The units I'm planning to use have titanium gearboxes and are pretty stout, but they also aren't cheap by any stretch of the imagination.
Maybe a mechanical fuse of some kind? I wonder if I could modify the servo arm linkage assembly to deliberately break away if I exceed a certain torque value. Might be as simple as replacing the linkage mounting bolts with nylon rivets or something.
I had to look up 'tensegrity structure'; I've seen those setups before, totally fascinating. It seems like I could make a large, lightweight safety cage using pulltruded CFRP rods and Kevlar thread. As long as I can keep it under 50 grams or so, that would be waaaay better than landing gear.
davedarko wrote 07/14/2014 at 08:36 point
I'm really looking forward to the videos of that thing flying! It's always a good idea to sleep over an order, I will never order pcbs after midnight again and I can recommend that to everyone :D there is a co-axial helium donut still buzzing in my head sometimes, it's good to know that here is a good place to start, should I ever feel the urge to build it. But fortunately there are enough things on my list. Probably a question that is redundant with all your research and plannings but have you checked every possible angle of the rotor blades vs. your frame? In the last picture it looks like the blades could touch the first frame because they are that high / far away from the pivot point that the blades are out of the frame radius.
zakqwy wrote 07/14/2014 at 12:22 point
I did some basic range of motion tests but I'll probably do it again to be sure. I might swap the prop models out (temporarily) for disks that represent their full rotation so I don't have to constantly adjust angles. Good call, shredding the frame and props on the first flight wouldn't be a good thing.
