Those familiar with the Arduino IDE are used to being able to immediately access Serial Data in the Serial Monitor after the sketch successfully uploads. That is not the case with the Arduino 101. After your program uploads, you need to wait 5 seconds before opening the Serial Monitor, or you will get the error below.
Frank Vigilante
