InoTech PHOTON
DLP Resin 3D Printer
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The Photon prototype will use extruded aluminium with 3d printed parts to connect everything together for the frame. I have a Mitsubishi XD60U DLP projector as the way to project the layers and cure the resin. I hope to figure out the right material to use for the bottom of resin tank which will allow the UV light as well as oxygen through so I can try and figure out a continuous printing method which would speed up the print time and also should do away with any visible layering. This "membrane" will allow enough oxygen through to make a small air gap in the resin so it wont stick to the bottom and as the printer pulls the forming object up, suction feeds more low-oxygen uncured resin toward the bottom. The process is called CLIP for "continuous liquid interface production."
I have gotten as far as modeling the Z axis assembly using Autodesk Inventor 2016. I have exported the STL files for the top and bottom of the assembly and sliced it with slic3r. About 3 ho
