Hackaday.io Hackaday.io
Sign up Log in
ETHERSYNTH
Analog synthesizer with digital control system.
dskoshelevdskoshelev
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
270 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
84
0
270
2
Team (1)
  • dskoshelevdskoshelev
Join this project's team
completed project
https://www.youtube.com/watch?v=_8-BrGNg9ko
This project was created on 03/04/2016 and last updated 11 years ago.
Description
I want to bring to your attention the prototype sound synthesizer ETHERSYNTH. Control by the microcontroller, as in modern synthesizers, because of the possibility of reception and transmission of MIDI messages via the USART, the controller memorize settings, free routing control signals, generating LFO various purposes. I chose the one already used in previous projects ATXMega128A1 and development environment IAR. To control voltages using PWM outputs with a low-pass filter, it turned four: first, - "pitch cv" to control the height of the main generator of the notes; secondly, - "cutoff cv" to control the frequency cutoff; Thirdly, - "amp cv" for controlling the output gain; Fourthly, - "pulse width cv" pulse width for the PWM control signal generator rectangular. As the controller generates two ADSR envelopes, which can be assigned to any of the control output. All parameters are set via MIDI. In addition Wi-Fi module inside to send MIDI messa
Details
Log In/Sign up to comment
Sign up with Github
OR
Its control and driver schematic and layout
Project Owner Contributor
inverted pendulum
gihadgihad
Control de iluminación robótica por pulsaciones dmx
Controlador DMX
octaviogressoctaviogress
Remote Control Animatronic Plush Shark
OPShark
dan-sheadelDan Sheadel
dropped TTL for a Ti430 to control a pop-less mic mute
mic mute v4
johnfosterjohnfoster
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ETHERSYNTH", please tell us the reason.
Send message
Remove Member
