3.) The rear wheel
entunassaEntunassa wrote 04/02/2021 at 18:14 • • 2 min read • Like
As mentioned before, the re-spacering of the rear wheel has an additional challenge:
That means: No frame modifications are accepted, I fear a crack in the stays.
The original condition fits in with too much force... not good
First attempt: The rim is *not* centered between the chainstays
After checking it with a caliper and recalculating the distances it turned out as follows:
Left side: 4mm bushing and nut taken from the front wheel
Right side: 8mm bushing and nut: The cogset fits perfectly
The rear dropout width is 120mm and the re-spacered axle now has 122mm. Good.
Next chapter: The bottom bracket
Like
