Product Overview
The LT ®1014 is the first precision quad operational amplifier which directly upgrades designs in the industry standard 14-pin DIP LM324/LM348/OP-11/4156 pin configuration. It is no longer necessary to compromise specifications, while saving board space and cost, as compared to single operational amplifiers.
This blog will introduce LT1014 systematically from its features, pinout to its specifications, applications, also including LT1014 datasheet and so much more.
LT1014 Features
- Single Supply Operation
- Pin Compatible to 1458 and 324 with Precision Specs
- Guaranteed Offset Voltage: 150μV Max
- Guaranteed Low Drift: 2μV/°C Max
- Guaranteed Offset Current: 0.8nA Max
- Guaranteed High Gain
- Guaranteed Low Supply Current: 500μA Max
- Low Voltage Noise, 0.1Hz to 10Hz: 0.55μVP-P
- Low Current Noise—Better than 0P-07, 0.07pA/√Hz
Input Voltage Range Extends to Ground
Output Swings to Ground While Sinking Current
5mA Load Current: 1.5 Million Min
17mA Load Current: 0.8 Million Min
LT1014 Pinout
The following figure is the diagram of LT1014 pinout.
LT1014 Applications
- Battery-Powered Precision Instrumentation
- 4mA to 20mA Current Loop Transmitters
- Multiple Limit Threshold Detection
- Active Filters
- Multiple Gain Blocks
If you want to know more about LT1014, you can read its datasheet.
