Product Overview
The CC2531 USB is a USB enabled true system-on-chip (SoC) solution for IEEE 802.15.4, cc2531 Zigbee and RF4CE applications. It enables USB dongles or USB upgradable network nodes to be built with low total bill-of-material costs. The CC2531 combines the performance of a leading RF transceiver with an industry-standard enhanced 8051 MCU, in-system programmable flash memory, 8-KB RAM, and many other powerful features.
The CC2531 has various operating modes, making it suited for systems where ultralow power consumption is required. Short transition times between operating modes further ensure low energy consumption.
This blog will introduce CC2531 systematically from its features, pinout to its specifications, applications, cc2531 home assistant, cc2531 zigbee, texas instruments cc2531, also including CC2531 datasheet and so much more.
CC2531 Features
●RF/Layout
- 2.4-GHz IEEE 802.15.4 Compliant RF Transceiver
- Excellent Receiver Sensitivity and Robustness to Interference
- Programmable Output Power Up to 4.5 dBm
- Few External Components
- Only a Single Crystal Needed for Asynchronous Networks
- 6-mm x 6-mm QFN40 Package
- Suitable for Systems Targeting Compliance With Worldwide Radio-Frequency Regulations: ETSI EN 300 328 and EN 300 440 (Europe), FCC CFR47 Part 15 (US), and ARIB STD-T-66 (Japan)
●USB
- USB 2.0 Certified Full Speed Device (12 Mbps)
- 5 Highly Flexible Endpoints
- 1-KB Dedicated FIFO
- DMA Access to FIFO
- No 48-MHz Crystal Required
- Low Power
- Microcontroller
- Peripherals
- Active Mode RX (CPU Idle): 24 mA
- Active Mode TX at 1 dBm (CPU ldle): 29 mA
- Power Mode 1 (4 μs Wake-Up): 0.2 mA
- Power Mode 2 (Sleep Timer Running): 1 μA
- Power Mode 3 (External Interrupts): 0.4 μA
- Wide Supply-Voltage Range (2 V- -3.6 V)
- High-Performance and Low-Power 8051 Microcontroller Core With Code Prefetch
- 256-KB or 128-KB In-System-Programmable Flash
- 8-KB RAM With Retention in AIlI Power Modes
- Hardware Debug Support
- Powerful Five-Channel DMA
- IEEE 802.15.4 MAC Timer, General-Purpose Timers (One 16-Bit, Two 8-Bit)
- IR Generation Circuitry
- 32-kHz Sleep Timer With Capture
- CSMA/CA Hardware Support
- Accurate Digital RSSI/LQI Support
- Battery Monitor and Temperature Sensor
- 12-Bit ADC With Eight Channels and Configurable Resolution
- AES Security Coprocessor
- Two Powerful USARTs With Support for Several Serial Protocols
- 21 General-Purpose I/0 Pins (19x4 mA, 2 x 20 mA)
- Watchdog Timer
●Development Tools
- CC2531 Development Kit
- Certified CC2531 USB Dongle Reference Design
- SmartRFTM Software
- Packet Sniffer
- IAR Embedded Workbench Software Available
CC2531 Pinout
The following figure is the diagram of CC2531 pinout.
If you want to know more about CC2531 USB, you can read its datasheet.
